dalesman Posted May 21, 2009 Report Share Posted May 21, 2009 Hi , As any one had trouble with a 1996 Beta clutch ,The clutch does not clear hot or cold. I have had the clutch apart and cleaned the plates, One of the steel plates was a nice shade of blue but it does not look bent , if anybody got any idea on the problem. Thanks. Quote Link to comment Share on other sites More sharing options...
nzralphy Posted May 21, 2009 Report Share Posted May 21, 2009 Blue is not good. It is likely someone has fryed the clutch. Remove all the steel and fibre plates and measure their thickness (call the importers for specs). I'm picking that they are worn out.... or.... your clutch needs bleeding. Quote Link to comment Share on other sites More sharing options...
