scorpaant Posted May 22, 2009 Report Share Posted May 22, 2009 Hello all I have recently bought a 96 scorpa easy 250 and have had a running problem with it. Firstly the carb was not the correct one, so i bought a keihin conversion, then i replaced the piston rings etc as there was no compression, but still had the same running problem. Which then left the stator plate. I sent it away to west country windings who have informed me that the pick up has failed and these are hard to come by. Do you know anywhere i can get a second hand stator, or if anybody has one spare? it has to be a 280ohm pick up. Many Thanks Ant Quote Link to comment Share on other sites More sharing options...
godzilla Posted May 22, 2009 Report Share Posted May 22, 2009 Try rathmells they still have some scorpa bits i think. Quote Link to comment Share on other sites More sharing options...
houseape1000 Posted May 25, 2009 Report Share Posted May 25, 2009 Hi, this isn't much help, but if you find a place to buy parts from be sure to give them a mention --please--. I have the same bike and its very difficult trying to locate parts. Are you sure the carb is the right one - I have just removed a 30mm carb because the bike wouldn't run and fitted a standard 26mm and all is fine.....I think..... Quote Link to comment Share on other sites More sharing options...
zaa9 Posted June 9, 2009 Report Share Posted June 9, 2009 i also snt my 1997 asy stater plate to west country windings, and they re-wound it. i dont know much on this subjct so excuse me if this is a stupid qustion, but cant the pickup coil be re-wound? thanks Quote Link to comment Share on other sites More sharing options...
