blackrandomapple Posted May 25, 2009 Report Share Posted May 25, 2009 Any one know if it is possible to get black fork tubes for my 2001 beta rev 3? Quote Link to comment Share on other sites More sharing options...
bob Posted May 25, 2009 Report Share Posted May 25, 2009 Hi, I think you can get the ones you have on at the moment coated if you really wanted to. But it isn't a cheap option unless they needed doing anyway. The black coating is just there as a low st'iction surface so they feel a bit smoother. Bob Quote Link to comment Share on other sites More sharing options...
blackrandomapple Posted May 25, 2009 Author Report Share Posted May 25, 2009 Hi,I think you can get the ones you have on at the moment coated if you really wanted to. But it isn't a cheap option unless they needed doing anyway. The black coating is just there as a low st'iction surface so they feel a bit smoother. Bob Do you know what sort of coating this is? I just want black ones thats all! Quote Link to comment Share on other sites More sharing options...
tombo46 Posted May 25, 2009 Report Share Posted May 25, 2009 Im not sure about coating, but If you wanted the tubes, I seem to recall them being in the 100's each. Tom Quote Link to comment Share on other sites More sharing options...
olliemoto Posted May 25, 2009 Report Share Posted May 25, 2009 Im not sure about coating, but If you wanted the tubes, I seem to recall them being in the 100's each.Tom expensive waste of time its a trials bike , not meant to look like a trickety christmas tree the tubes get worn down and the coulor fades quick depending on how much u use ure bike Quote Link to comment Share on other sites More sharing options...
blackrandomapple Posted May 27, 2009 Author Report Share Posted May 27, 2009 expensive waste of timeits a trials bike , not meant to look like a trickety christmas tree the tubes get worn down and the coulor fades quick depending on how much u use ure bike After doing my research i have decided not to do it, The coating does reduce friction, It a diamond sort of coating, But as stated the coat will come of over time and then its looks stupid! Quote Link to comment Share on other sites More sharing options...
