dickiem Posted May 25, 2009 Report Share Posted May 25, 2009 Been out on it a few times now (had it about a month) and I'm not sure if the motor is knocking in some way or it's just a normal noise. It starts and runs OK (but doesn't like ticking over, despite altering that). What are the classic symptoms of big end/little end bearing wear, how do you identify which it is and how big a job are they to change? I'm pretty confident at having a go DIY but don't want to do a bottom end strip down if it's only a top end problem.....or should I just leave it until running is affected? Quote Link to comment Share on other sites More sharing options...
lineaway Posted May 25, 2009 Report Share Posted May 25, 2009 Have you cleaned the carb and checked the pilot jet? The knock could just be a lean condition from a blocked or too small of jet. It will also fix your idle problem. Quote Link to comment Share on other sites More sharing options...
dickiem Posted May 25, 2009 Author Report Share Posted May 25, 2009 Have you cleaned the carb and checked the pilot jet? The knock could just be a lean condition from a blocked or too small of jet. It will also fix your idle problem. I haven't no but that might be a good suggestion, tried a couple of steep inclines recently and it felt choked up so that might be the culprit Quote Link to comment Share on other sites More sharing options...
dickiem Posted May 28, 2009 Author Report Share Posted May 28, 2009 Have you cleaned the carb and checked the pilot jet? Right, gonna have a go at this tonight. Excuse my ignorance, but which jet is the pilot jet? Downloaded a service manual but the details are vague and nothing has any detailed labelling Quote Link to comment Share on other sites More sharing options...
benbeta23 Posted May 28, 2009 Report Share Posted May 28, 2009 (edited) The pilot jet is the side jet, you should be able to notice the size difference between the pilot & the main jet I also have this knocking noise on my bike, i took the bike to go on a dyno-mometer, and the guy reccomended a different pilot jet as the bike was running rich & a different needle, so i have ordered them & he said it should be perfect when they are put in. but i still haven't got the jets yet lol. It didn't help at all with Sam Haslam taking the original Keihin carb off, which was set up by GG UK prefectly with the right jets (factory secret), and putting a standard dellorto back on, i have bought another Keihin for it now, but still with standard jets in, so i'm going to get them changed ASAP! Cheers Ben. Edited May 28, 2009 by GasGasben Quote Link to comment Share on other sites More sharing options...
dickiem Posted May 28, 2009 Author Report Share Posted May 28, 2009 ....the guy reccomended a different pilot jet as the bike was running rich & a different needle, so i have ordered them Do you have details (sizes) of what's been ordered. Cleaned mine out tonight and no difference Quote Link to comment Share on other sites More sharing options...
benbeta23 Posted May 29, 2009 Report Share Posted May 29, 2009 Do you have details (sizes) of what's been ordered. Cleaned mine out tonight and no difference I don't know exactly, because my dad ordered them, although i think the pilot jet is 40, if the standard one is 45 I'll ask about the needle though. Quote Link to comment Share on other sites More sharing options...
