99 Gasgas Contact Txt 270
scotty97
i have just bought a 99 txt 270, and the oil sight in the side of the gearbox seems to b leaking slightly, can i just unscrew it and replace the seal?? What size socket do i need? A 16mm is to small, and a 17 doesnt want to go down over it (i think the outside of the socket is hitting case), or is there a certain spanner i could use
right i modified a 17mm socket and it fits perfect. replace the oil sight and the copper washer, and it still seems to leak a tiny bit of oil, when left for a few hours. Anyone else had this problem????? i was thinking of using a fibre washer instead of copper to try and get a better seal, any suggestions???
