Bike Wanting To Go Backwards
sherco25016
i had started my sherco up from hot today and i pull the clutch in and knocked it into gear
when i let the clutch out it went backwards and engine was makin a funny noise
it did it to me twice today is there somet tht has broke in the gearbox or something any ideas on the problem will be great
thanks josh
I had an early John Shirt MAJESTY 320 and that ran backwards in a section... once!!!
Scared me witless.
John reset the timing and it never ran backwards again...
Unless you have a Harley and you accidentally selected reverse... :thumbup:
P
I seem to recall someone experiencing this condition a long time back. I cannot recall if is was the coil/box or the stator that caused it.
Obviously the coil/ box is the easiest to try first. Depending upon your location, a call to MRS may help firm up this info. :thumbup:
Edited by copemech
i had a new stator fitted in september
wonder if that is the problem i will give the shop a ring where i got it fitted from
thanks josh
Short of learning to ride with your hands behind your back...
suggest you check for a loose flywheel nut and/or a sheared flywheel key,
and while you have the flywheel off check the position of the stator plate and timing mark.
:thumbup:
:blink:
Yea, agree, as in that case may have slipped a widget! :thumbup:
