incognuity Posted May 31, 2009 Report Share Posted May 31, 2009 How much oil per 5 litres of petrol should I use? I'm all new to trials bikes but a friend recommend 3% oil to petrol. The bike was empty of fuel from being out on it yesterday so I filled it up with the 3% mix this morning but I soon found the bike very stuttery - e.g. in 1st gear on level ground with the clutch fully out the bike almost wanted to stall. The tip of the exhaust was also very oily. Is this a sign of too much oil? Would 2% be a better mix? Quote Link to comment Share on other sites More sharing options...
steve1979 Posted May 31, 2009 Report Share Posted May 31, 2009 75ml to 5 litre's should be fine Quote Link to comment Share on other sites More sharing options...
andysv1k Posted May 31, 2009 Report Share Posted May 31, 2009 would 75ml be good for all years? Also, any reccomnedations for oil brand and type. Andy. Quote Link to comment Share on other sites More sharing options...
crasher Posted May 31, 2009 Report Share Posted May 31, 2009 75ml is good for most watercooled engines, aircooled engines require more oil 50-1 equates to 100ml i think, i use motul 710 fully synthetic Quote Link to comment Share on other sites More sharing options...
steve1979 Posted May 31, 2009 Report Share Posted May 31, 2009 AndySV1K said: would 75ml be good for all years?Also, any reccomnedations for oil brand and type. Andy. there's a point, i would think 75ml would be okay for all years but perhaps an older bike with a bit more play in the engine would'nt hurt to run a little extra oil to be on the safe side just might be a little smokier, i'm sure someone will clarify that though as for oil type i always use putoline mx7 or the mx5 the mx7 is fully sythetic and the mx5 is semi synthetic if i remember correctly, the mx7 is a little dearer by a couple of pound per bottle, the putoline is good qaulity and you would'nt go far wrong with that. I'm no expert though mind, but there are my thoughts on fuel ratio and brand. Hope that helps Steve Quote Link to comment Share on other sites More sharing options...
incognuity Posted May 31, 2009 Author Report Share Posted May 31, 2009 Would having too much oil like I had today explain why the bike felt like it was wanting to stall? Quote Link to comment Share on other sites More sharing options...
steve1979 Posted May 31, 2009 Report Share Posted May 31, 2009 I'm not sure buddy, what year is your bike? if my maths is correct 3% of 5 litre's is 150ml which does sound like alot. someone told me that a with a good qaulity oil you should'nt need so much Quote Link to comment Share on other sites More sharing options...
steve1979 Posted May 31, 2009 Report Share Posted May 31, 2009 Just seen yours is a 2005 from your introduce yourself post, so 75 ml will be ample, double that and perhaps the fuel mixture would be out causing it to stall so for 5 litre's you would need 1.5% of oil. Cheers, Steve Quote Link to comment Share on other sites More sharing options...
incognuity Posted May 31, 2009 Author Report Share Posted May 31, 2009 Cheers Steve. Yeah the bike is a 2005. The bike was stalling a lot today which was annoying... I thought it was just me! lol Quote Link to comment Share on other sites More sharing options...
steve1979 Posted May 31, 2009 Report Share Posted May 31, 2009 lol, try the 75ml and hopefully all will be well on the stalling front Quote Link to comment Share on other sites More sharing options...
jse Posted June 1, 2009 Report Share Posted June 1, 2009 incognuity said: Cheers Steve. Yeah the bike is a 2005. The bike was stalling a lot today which was annoying... I thought it was just me! lol The 75ml per 5 Litres should work well (use a full-synthetic premix oil). You also may want to re-set the fuel screw (engine warm and in neutral, quickly blip throttle from tickover and adjust screw in/out to get best response) and set the tickover speed with the engine in 1st gear and the clutch lever pulled in the "normal" way (not all the way to the grip, but usually in with one finger to the knuckle) and you shouldn't have any stalling problems. Cheers. Jon Quote Link to comment Share on other sites More sharing options...
