geebee Posted June 1, 2009 Report Share Posted June 1, 2009 Gentlemen Your help would be appreciated to help me locate the various parts of this tubeless tyre inflation valve assembly. The assembly comprises the following parts: Main Stem housing valve Two rubber washers (one either side of sealing strip?) One domed metal washer (between lower rubber washer and knurled ring) One knurled metal ring (between domed washer and wheel rim) One nut (external to wheel rim) One valve cap (obvious) Ther is no spacer with this assembly and the assembly appears a little deep inside the rim. Quote Link to comment Share on other sites More sharing options...
stevec Posted June 1, 2009 Report Share Posted June 1, 2009 This help? http://www.shercousa.com/pdfs/rim_band_rep...ment_manual.pdf from: http://www.shercousa.com/?action=9 Quote Link to comment Share on other sites More sharing options...
copemech Posted June 2, 2009 Report Share Posted June 2, 2009 You do not need a spacer. If it is in good shape just tighten the ouside nut lightly and it will seal against the band. If not, I would order up one of them new integrated stem/ bands and chunk the lot!. Quote Link to comment Share on other sites More sharing options...
geebee Posted June 2, 2009 Author Report Share Posted June 2, 2009 Thanks Guys Geebee Quote Link to comment Share on other sites More sharing options...
arnoux Posted June 5, 2009 Report Share Posted June 5, 2009 or HERE Quote Link to comment Share on other sites More sharing options...
