blackrandomapple Posted June 3, 2009 Report Share Posted June 3, 2009 Hey folks! Im having a bit of troule with my clutch, the other day when i was out my clutch started to slip in 3 going up a steep rocky hill, I cam home a took the clutch plates out for inspection, all was fine so i rebuilt bike with fresh oil and took it for a spin! It had stopped slipping but is now rattling and dragging slightly Also after only a few hours riding the oil is pretty black compared to normal, One last thing, Does anyone in gloucestershire have a spare clutch spring? lost it in the garage some where rggghh!!!! Any help please? Quote Link to comment Share on other sites More sharing options...
02-apr Posted June 3, 2009 Report Share Posted June 3, 2009 I wouldn't worry about the spring. I took two out of mine to lighten the action and there was no problem with slippage but it is a 200. Quote Link to comment Share on other sites More sharing options...
blackrandomapple Posted June 3, 2009 Author Report Share Posted June 3, 2009 I wouldn't worry about the spring. I took two out of mine to lighten the action and there was no problem with slippage but it is a 200. Do you reckon it will be ok with a spring missing then? the clutch plate does move slightly uneven now, If i can i will get one from bvm tomo but im not sure they will have one in stock! Quote Link to comment Share on other sites More sharing options...
blackrandomapple Posted June 4, 2009 Author Report Share Posted June 4, 2009 Ive read alot about automatic transmission fluid instead of normal oil, would this be a good idea? is there a certain type i need? Quote Link to comment Share on other sites More sharing options...
fivemeister Posted June 4, 2009 Report Share Posted June 4, 2009 Do you reckon it will be ok with a spring missing then? the clutch plate does move slightly uneven now,If i can i will get one from bvm tomo but im not sure they will have one in stock! Take another one out to balance it. Will be fine. Quote Link to comment Share on other sites More sharing options...
blackrandomapple Posted June 4, 2009 Author Report Share Posted June 4, 2009 Take another one out to balance it. Will be fine. Got a new one today! Thanks tho Quote Link to comment Share on other sites More sharing options...
