godzilla Posted June 4, 2009 Report Share Posted June 4, 2009 (edited) Why are you ment to change the plug so regularly on the rev4? I have a new plug but i am loathed to change it for no good reason. (i am that tight) Edited June 4, 2009 by godzilla Quote Link to comment Share on other sites More sharing options...
rlracer Posted June 4, 2009 Report Share Posted June 4, 2009 I have had 2- Rev 4's, 07,08, & an evo and have not changed a plug in any of them all have ran fine. No problems with plugs, good fuel and a little jetting. Quote Link to comment Share on other sites More sharing options...
nzralphy Posted June 5, 2009 Report Share Posted June 5, 2009 I've had no issues with my plug. I fitted an Iridium and it has never fumbled. It often looks very sooty / black but it runs fine. Gap the plug at 0.6mm and I run 3-3.5 turns of mixture screw. Lampkin's suggest a new plug every few rides and i can't figure out why.... if you run a very rich idle mix (four turns out) as they suggest perhaps they are fowling plugs? Perhaps they have shares in NGK? Ralphy Quote Link to comment Share on other sites More sharing options...
