Ty 250 Twinshock
skippy1234
I know this sounds daft but it has happened to me with a TY 250.
Make sure the carb airscrew hasnt fallen out, it happens, and also check that the feed from the oil pump, if it has been removed and the bike converted to pre mix, has been blanked off properly.
I'd agree with the previous c\omments but worth trying the obvious ones.
Oh yes also check the inet manifold for air leaks.
hi all i replaced bottom top and reed gaskets still the same air filter then i noticed a little jet in the carb i missed the first time round guess what it was blocked it is sweet as a nut now thanks for all the replies cheers mick
