hoodie2 Posted June 8, 2009 Report Share Posted June 8, 2009 For my M92 project I have the offer of a barely used Dellorto, from a 2003 Gas Gas pro 300. I havent got it to measure yet but I think the spiggot OD is 31mm. Does anyone know if this is right and what carb rubber I need to fit to the two stud amal fitting? Does anyone in the UK sell a rubber for an amal to dellorto conversion? Cheers Hoodie. Quote Link to comment Share on other sites More sharing options...
ryanroz Posted December 21, 2009 Report Share Posted December 21, 2009 Hughs bultaco sells a carb adapter conversion plate here in the US. http://www.buybultaco.com/Merchant2/mercha...egory_Code=CARB http://www.buybultaco.com/Merchant2/mercha...egory_Code=CARB Depending on which Dellorto carb you got from the 2003 gasgas (round or flat slide) you may need the rubber adapter to go into the air side (Gas Gas part) Quote Link to comment Share on other sites More sharing options...
