dabomb Posted June 10, 2009 Report Share Posted June 10, 2009 (edited) My mate has a rev3 125,which has developed a rattle.We took the barrel off and discovered that the little end was worn and thought that this was causing the propblem. There was also a bit of an area at top of the bore which looked worn,about 10mm from top of bore and about 15mm wide.Not sure what caused this.We replaced the bearing and gudgeon pin and gave it a new set of rings. When the bike was fired up,the rattle was a lot better but still there.When we had the barrel of,we noticed some sideways play in the big end,but no up down play.Could the play be causing the rattle?,or has anybody got any other ideas? Thanks in advance. PS it an 05 model Edited June 10, 2009 by dabomb Quote Link to comment Share on other sites More sharing options...
chewy Posted June 10, 2009 Report Share Posted June 10, 2009 have you listened with screwdriver or (even better) stethascope..... you can locate exacly where rattle is using a "tool" like this Quote Link to comment Share on other sites More sharing options...
blackrandomapple Posted June 10, 2009 Report Share Posted June 10, 2009 Sideways play is normal as ar as i know, aslong as there is no up and down play! i have a rattle but it is something to do with the clutch, From what i have read its a common beta rattle, Quote Link to comment Share on other sites More sharing options...
