braddon Posted June 15, 2009 Report Share Posted June 15, 2009 I went to switch of my 2002 rev3 the other day using the handle bar mounted cut out switch and it would not work. Checked the wiring and all seems to be fine. I have to stop it by stalling it at the moment as no other way. Any suggestions as to what the problem may be would be appreciated. Thanks Quote Link to comment Share on other sites More sharing options...
blackrandomapple Posted June 15, 2009 Report Share Posted June 15, 2009 I went to switch of my 2002 rev3 the other day using the handle bar mounted cut out switch and it would not work. Checked the wiring and all seems to be fine. I have to stop it by stalling it at the moment as no other way. Any suggestions as to what the problem may be would be appreciated. Thanks New killswitch maybe Quote Link to comment Share on other sites More sharing options...
braddon Posted June 17, 2009 Author Report Share Posted June 17, 2009 Sorted. There was a mere wire came detached under the push button. A lump or solder and job done. Cheers Quote Link to comment Share on other sites More sharing options...
gaz Posted June 17, 2009 Report Share Posted June 17, 2009 The best you can do is replace the switch for a yam style one. the beta ones look nice but are crap. I think loads of people have trouble with them, i didint really believe it til it happened to me!!! If you do change it, your also best off moving the ground from the fork yolk to somewhere like behind the coil. loads of threads on doning this mate Quote Link to comment Share on other sites More sharing options...
