ausy300pro Posted June 15, 2009 Report Share Posted June 15, 2009 Has anyone had any bother with spltting the case on the 175 engine, I cannot get mine apart, first one in 40 years of doing my own engines that I can't get them to split, they are moving apart ta the main bearing end but wont budge at the back of the engine, I thought there must be a hidden screw somewhere but have got a new set of crankcase allen screws to rebuild with and there are 12 and I have taken out 12 screws, is there something peculiar about splitting this engine ? Quote Link to comment Share on other sites More sharing options...
scorpa250 Posted June 15, 2009 Report Share Posted June 15, 2009 Sounds like the rear engine mount ,it has a rubber insert ,from memory this can be a siezed in the cases .goog luck .scorpa250 Quote Link to comment Share on other sites More sharing options...
trialsmm Posted June 15, 2009 Report Share Posted June 15, 2009 Keep tapping it lightly with a rubber mallet. Quote Link to comment Share on other sites More sharing options...
ausy300pro Posted June 15, 2009 Author Report Share Posted June 15, 2009 I think you could be right with the rear engine mount, it looks like it is round there that it is not moving, I have been using the rubber mallet (well nylon actually cos I find that rubber does not transfer enough of the shock to get it moving) Thanks Quote Link to comment Share on other sites More sharing options...
ausy300pro Posted June 16, 2009 Author Report Share Posted June 16, 2009 victory is mine, the cases were stuck on the large dowel at the rear of the engine where the rubber mount is, it was corroded together in cases, had to use lots of heat to get it apart but it's done now. Quote Link to comment Share on other sites More sharing options...
