stephen1967 Posted June 27, 2009 Report Share Posted June 27, 2009 Hi there,this is my first post on here,I have a Beta Rev 3 250cc,2005 model.The bike has very high compression,i.e. the kick start is very hard to kick down.Recently I have noticed if I go down any steep hills the bike locks it`s back wheel and wants to stall.Are the two connected in any way and is there a way to fix this ?. I am not the world`s greatest mechanic but any help would be much appreciated. Quote Link to comment Share on other sites More sharing options...
nzralphy Posted June 27, 2009 Report Share Posted June 27, 2009 Hi and welcome The betas do have high compression (hence their need for high octane gas) and it is normal to be hard to kick over. you will get used to it. If you want a more docile bike i'd suggest you lower the compression by putting 2 or 3 base gaskets under the barrel. Killing an engine going down hill is easily done with a small touch of rear brake.... or perhaps your bike hasn't had some of the carburetor mods done as suggested in the 'Beta Forum'. Ralphy Quote Link to comment Share on other sites More sharing options...
lee harris Posted June 28, 2009 Report Share Posted June 28, 2009 (edited) The hard kick down has more to do with the flywheel and internal mass than the compression. My 250 PE suzuki has a much higher compression than my 249 fantic but feels lots easier to kick over. It has a very small flywheel! Edited June 28, 2009 by Lee Harris Quote Link to comment Share on other sites More sharing options...
