thedktor Posted July 16, 2009 Report Share Posted July 16, 2009 Think I posted having problems getting one of the gearbox bearings out, in a blind hole. The bearing is conical, and a small amount of leverage popped out the balls and carrier leaving a conical internal surface and no space behind to get anything substantial in to grip: So I ended up grinding it out (no damage to the case Quote Link to comment Share on other sites More sharing options...
feetupfun Posted July 18, 2009 Report Share Posted July 18, 2009 A less traumatic way to do that job is to use a stick welder to run a weld bead around the inside of the bearing outer. When this cools the weld shrinks the bearing outer and it will usually just fall out. Quote Link to comment Share on other sites More sharing options...
