trialsteve Posted July 19, 2009 Report Share Posted July 19, 2009 (edited) Hi all,Ihave a 2000 model 250 beta rev3. The bike starts and runs at low revs perfectly,at about half throttle it starts to missfire,and can't seem to clear itself. I have cleaned the carb which did not help,adjusted the air screw to lean the mixture and it seemed to help a little. I could be wrong,but the bike seems to be running very ritch,but have ho idea what has caused it. Could be a weak spark?? Hope someone can help,many thanks Edited July 19, 2009 by trialsteve Quote Link to comment Share on other sites More sharing options...
feetupfun Posted July 19, 2009 Report Share Posted July 19, 2009 You have perfectly described the symptoms for the same mode of ignition stator failure that occurred on my 2003 Rev 3 Beta. Unfortunately, stator failure on Betas of that era are relatively common. Quote Link to comment Share on other sites More sharing options...
trialsteve Posted July 19, 2009 Author Report Share Posted July 19, 2009 I was kinda thinking of the bottom windings. What is the next step? Can I test them? Can they be repaired,or is it new parts? Quote Link to comment Share on other sites More sharing options...
feetupfun Posted July 19, 2009 Report Share Posted July 19, 2009 I live in Queensland, Australia and the local Beta dealer has an exchange service, with the stators being rewound locally. The rewound stators don't fail. The only way I know of for testing them is to borrow one off a mate and see if it fixes the problem. Beware not all Rev 3 models have the same connections - I think yours will have a different number of wires to later model stators so you will probably need to find someone with a 2000 model if you want to test it out. Quote Link to comment Share on other sites More sharing options...
trialsteve Posted July 19, 2009 Author Report Share Posted July 19, 2009 Any body else came across this prob with a 2000 rev3? Quote Link to comment Share on other sites More sharing options...
sawtooth Posted July 20, 2009 Report Share Posted July 20, 2009 (edited) Check your coil, CDI and kill switch wiring for a loose connection, failing that your stator could be on its way out. Also worth trimming the end of your HT lead a little on the spark plug end. Edited July 20, 2009 by SawTooth Quote Link to comment Share on other sites More sharing options...
feetupfun Posted July 20, 2009 Report Share Posted July 20, 2009 Hey Steve there are plenty of postings already on the Beta forum about your problem. Heres a search on stator http://www.trialscentral.com/forums/index....hlite=%2Bstator Quote Link to comment Share on other sites More sharing options...
kwak7 Posted July 20, 2009 Report Share Posted July 20, 2009 Steve My 2000 rev3 had similar issues. It would start but die as soon as you gave it a rev, then it just gave up starting too. After spending ages stripping down and rebuild and checking electrics etc I finally gave up and bought a stator, coil and CDI from Lampkins who said just send back the ones that you dont need. It tuned out to be the CDI in the end and the bike now starts and runs like a dream!! Hopefully it's not the stator as a new one is pricey for 2000 rev3. There's a company called 'West Coast Windings' (google them) who will do a full re-wind for about Quote Link to comment Share on other sites More sharing options...
sawtooth Posted July 20, 2009 Report Share Posted July 20, 2009 (edited) Looked into WestCoast before, turns out better to buy a new stator from BVM which comes with a 12month warranty, there was only about Edited July 20, 2009 by SawTooth Quote Link to comment Share on other sites More sharing options...
kwak7 Posted July 20, 2009 Report Share Posted July 20, 2009 just make sure that's the correct stator for the 2000 bike. They are about Quote Link to comment Share on other sites More sharing options...
sawtooth Posted July 20, 2009 Report Share Posted July 20, 2009 just make sure that's the correct stator for the 2000 bike. They are about Quote Link to comment Share on other sites More sharing options...
