Ty175 Clutch Engagement
tyben
I have a yamaha ty175 and the clutch lever has to be let almost right out before it engages. I have tightened the adjuster on the handlebar in as far as it will go and it still is to far out to be able to control it properly when riding.
Is there anyway of adjusting it more maybe on the engine end so that it engages a few centimetres from the handlebar.
Thanks
You can gain a bit more adjustment from the cable itself. There are adjusters at the top of the cable. Then if that is still not sufficent, take off the flywheel cover and you will see a nut with a little cross headed bolt sitting inside it. This is situated roughly below where the clutch arm goes into the crankcases. This is the clutch release mechanism. The Haynes manual has a good section on how to set it. Best of luck. Gaz
