Opinion On Oils
bogwheel
Just wondering what gearbox oil people are using these days.
I would like to try synth equivilant 10W/30 or /40 as i use in my gas gas - can anybody comment please?
I will stay with ATF in the clutch though.
Also i have just rebuilt my M199 forks (just two new o-rings and made up new piston seals)what a difference. the forks are now the best i have ever had on a Taco but feel a bit firm for my light weight.
I have always gone by the what is the norm (180cc - SAE 20/25) can anybody comment on a lighter oil or more airspace before a go to the effort of changing it.
thanks
Hi in the 199 gearbox the recommended oil is EP90 -
usually available from car factors or lawnmower shops.
Using 10w40 proper motorcycle gearbox oil is ok - 500ml
don't use car 10w40!
In the forks the std oil is 15wt fork oil , you could also
try more oil in each fork , but don't go over 200ml in each leg.
If they are still too soft then install new springs.
Hi - For my Bultaco I always use 600ml Castrol ep 90 in the gearbox. Older manuals recommend sae 140 but its hard to get and probably ep90 has superceeded it anyway.
For the forks I use 180ml Castrol synthetic sae 10. Other people I have come across use atf and some heavier oils - depends how you like your forks to feel I guess. If they are not fitted already, a set of top nuts with valves are a good modification over standard.
Tim
Edited by bultaco49
Thanks for your input.
I will go to a lower grade oil @ 180cc first.
I have the top nuts with valves fitted - i thought this was only to let built up air out - is this correct, or is there another purpose please?
  • 2 weeks later...
