Checking Gearbox Oil?
stushine
I have the same bike and also like to know which oil is used best.
I think I have the wrong oil in now. With the engine switched off, when I select 2nd gear, clutch in, I can hardly push the bike. Sometimes the clutch is hardly working, crank turns over, but after some more trying, it start to work but still hard to push. It looks like the clutch plates are sticking. Stushine, is your bike also like this?
That sounds fairly normal to me, new oil will improve it slightly but they still drag a lot while the engine is off.
I use Ipone Gear Box oil, I think it is call Box 2 but any good synthetic light motorcycle gear box oil will do.
Some use ATF but this tends to make the clutch snatchy, some like it, I don't personal preference thing
