125 Misfiring Problem
betarob
Hey there,
I've got a 2009 125 gasser and it suffers with the seemingly usual, misfiring problem.
Specs: (maybe add-ons could be cause?)
Keihin 28 mm carb,
Boyesen reeds,
raga inlet manifold
We run the bikes on a 70:1 mix which is fairly lean i suppose, but when its not misfiring it runs so so cleanly and sweetly.
The bike will run absolutely great and then start misfiring and backfiring, even sometimes with flames out of the exhaust!
If the bike is then revved until nearly ceasing it clears and runs fine again.
It is maintained extremely highly with the filter/crab cleaned after every virtually every trial.
Could anyone shed some light on the diagnosis and treatment of the problem?
Thankyou
Rob
i know it sounds basic but start by just changing the plug. and try the bike again. if it still does it, it sounds like ignition. but what part of it i dont know.
i did have a 125 beta 2007 and that suffered from missing on the bottom end but only when it got hot. turned out it was the stator. theres a bloke in spain who can xray the stators to find out if there is something wroung with them then he fixes them. cost just under
