dickiem Posted July 30, 2009 Report Share Posted July 30, 2009 Hi, I need to change the output shaft seal (sits in the gearbox casing and around the shaft which the small sprocket fastens to) but I can't see any way of getting hold of it to remove it...any suggestions? Quote Link to comment Share on other sites More sharing options...
yamahaty250xox Posted July 30, 2009 Report Share Posted July 30, 2009 Ive just done this on my 125. p*** easy! Just hook it out with a flat blade screw driver. Dont go in too deep because there is a bearing behind it! But nice and easy it just flops out. Quote Link to comment Share on other sites More sharing options...
dickiem Posted August 3, 2009 Author Report Share Posted August 3, 2009 Ive just done this on my 125. p*** easy! Just hook it out with a flat blade screw driver. Dont go in too deep because there is a bearing behind it! But nice and easy it just flops out. Cheers mate, managed to do it as you said...leak cured Quote Link to comment Share on other sites More sharing options...
