Txt 125,can It Be Made Into A 200 Or 250?
dabomb
i was told that if you leave the inserts in it makes it too fierce, the power delivery is like an on off switch, it's a bit like that if you don't put a flywheel weight on as well, i'm sure there are other people on here that can give you the proper technical description, something to do with reducing the crank volume too much for the bigger piston or something like that
