Gg250 Pro Tuning
laser1
Spent a couple of hours testing pilot jets today in hot weather and familiar sections. The slow, tight uphill sections really help resolve any question regarding one jet over another. Smaller pilots = smoother power, and less of it. the #35 felt like I was riding a 200!
Original pilot was the best for me. Changed it back.
My buddies 250 (same gearing as mine) with a Keihin is smoother off the bottom, better feel and has just about as much power as my bike on the pilot - more everywhere else. Has very good over rev as expected. (the over rev isnt a goal for me other than just playing around) Im going to try the VHST next rather than any slide work.
26mm VHST - ran S32 (or S34) pilot, D37 needle - clip on groove 2 from bottom, 271HE needle jet, 120 or 118 main.
I played with the pilot size & needle clip postions to get best response.
Gave crisp smooth power. (on UK fuel!)
The VHST needs a 300 float jet - otherwise it runs out.
I tuned down the outlet to fit the std GG intake manifold.
Or you need the bigger manifolds as used with Keihin.
I always found the std dellorto too rich at/near idle.
Let me know how you get on,
Cheers, Mike
Cheers, Mike
Thanks for all the info Mike. I'll probably turn down the outlet so I can easily compare to PBHL.
  • 4 weeks later...
Update:
Switched to a VHST and after trying various jetting combo's, now have the bike running very nice. I find the VHST smoother w/better throttle response way down low (what I was looking for) with smoother/higher over rev. I was happy with the PBHL, but feel the change are worth it as I had access to a "free" VHST. (the cost of the jets, needles and fuel valve was a total of $80)
I really appreciate all the input folks gave me - especially the insight provided by Senior Blanco (Marlintec)
