sawtooth Posted August 4, 2009 Report Share Posted August 4, 2009 Following on from 'FatBars on Rev3' i'm wondering if the top yoke from an EVO will fit the forks from a Rev3? Can't find an email address for Paioli and without actually buying one and trying it i'm not sure of the sizes. All i could find on the Paioli website was basic fork specs.... CONV. 38 REV 3 Trial fork -Fork:Conventional> -Tube diameter: 38 mm -Total length: 760 mm -Stroke: 170 mm -Other tube: chill cast of alloy -Upper bracket: chill cast in primary aluminium alloy, painted silver -Lower bracket: heat forged in aluminium alloy, anodised silver -Sliding: on double DU cam (1 on the sleeve and one on the tube) -Regulations: in compression, extension and spring pre-load -Internal operation: mixed. The right "Z" outer tube contains a cartridge, with all components machined from solid aluminium, while the left leg contains Quote Link to comment Share on other sites More sharing options...
anyoldiron Posted August 4, 2009 Report Share Posted August 4, 2009 Might have missed something on previous thread.08 rev 3 top yoke.Fat bars as standard.Dont know about the Evo tho. Quote Link to comment Share on other sites More sharing options...
mrkartoom Posted August 5, 2009 Report Share Posted August 5, 2009 You'd need to know offset, fork dimensions, yoke size, clamp height, etc. If they are all 38mm forks then that part would fit, but too many other factors to consider. Maybe a dealer would know if no one has tried it, or be able to examine them side by side. Quote Link to comment Share on other sites More sharing options...
sawtooth Posted August 5, 2009 Author Report Share Posted August 5, 2009 Hmm, i wasnt aware that the '08 had FatBars as standard, that might be an option. If i had the 2 yokes side by side i'd be able to accurately measure them at work on a CMM, but buying them on the off chance isnt really an option. Next time im in my local dealers i'll see what they think. Quote Link to comment Share on other sites More sharing options...
sawtooth Posted August 5, 2009 Author Report Share Posted August 5, 2009 I just had a thought.... the VMAR top yoke dosent specify different years for fitment. If the VMAR top yoke fits ALL rev 3's then a standard Beta 2008 top yoke will fit other years too. Question is, which one is cheaper, VMAR or Beta? Quote Link to comment Share on other sites More sharing options...
anyoldiron Posted August 5, 2009 Report Share Posted August 5, 2009 I think the top yoke is Quote Link to comment Share on other sites More sharing options...
sawtooth Posted August 5, 2009 Author Report Share Posted August 5, 2009 SXS has them for Quote Link to comment Share on other sites More sharing options...
