m0agi Posted August 8, 2009 Report Share Posted August 8, 2009 Hi There I crashed today and broke the clutch lever. No Problem thinks I as i had a spare back in the van...........BUT...... When i came to fit it i found i had lost the rubber boot assembly which i think looking at the brake lever must contain some kind of push rod, because when i fitted the new lever, even with the adjuster right out it would no where near engage the clutch. Can someone just confirm what i need to get hold of as i do not have a parts book. the bike is a REV3 125 2005 Model. Many Thanks Geoff Quote Link to comment Share on other sites More sharing options...
martinf Posted August 9, 2009 Report Share Posted August 9, 2009 If it is anything like my 250 you'll also have the same thing on the front brake so you can have a look for reference. I've no idea what it's called but every time I've needed something I've called Lampkins and they've got me what I need very quickly. Quote Link to comment Share on other sites More sharing options...
anyoldiron Posted August 9, 2009 Report Share Posted August 9, 2009 Also Lampkins have all the engine and parts lists on pdf file on the website,also pricelist,which is handy Quote Link to comment Share on other sites More sharing options...
