Misfire When Warm
outlaw0robo
Also worth checking on the older 4rts are the 2 wires, terminals and earth on the ht coil. These can get pretty corroded.
Too true Sunt, David's 07 bike had an intermittent cutting prior to the SSDT, which was only cured when the wiring harness was replaced (thanks Munch for the advice on that point!) It was the wires leading into the coil that were at fault. Wiring harness is not expensive around
