bodgit0_0 Posted August 17, 2009 Report Share Posted August 17, 2009 Decided to run my Beta Techno 1995 on the road for a while. Have fitted a set of lights that have been bench tested to confirm they are good including the horn. Tried stealing a feed from the power that goes to the electric fan. Have found the voltage to be all over the place from 2 volts with my light loom connected, then 6 volt on the bike alone, and sometimes it will run at 12 volts. The more that is on the lower the volts are?? I have the brown wire from the stator running up to a black box which then comes back out to a silver box that gets very hot. Can anyone confirm how the bike should be wired, or away to sort a viable output that will feed both the fan and lighting loom. I know I could run it on a day-time MOT but will be taking to work and the hours are all over the place. Cheers for any advice offered Lee Quote Link to comment Share on other sites More sharing options...
