tudor Posted August 18, 2009 Report Share Posted August 18, 2009 Hi, I would be very grateful if anyone could post a picture or a drawing of a standard SY250 flywheel, ideally with the dimension of the outer width of the flywheel. Mine has been machined to make it lighter, the overhang has been removed plus an additional 6 or 7mm milled away so I'm planning to spot weld a 14mm wide ring to end up with a total flywheel weight of 3.1kg. It would be very useful to see what the flywheel looked like before being machined. Many thanks for your help. Quote Link to comment Share on other sites More sharing options...
godzilla Posted August 19, 2009 Report Share Posted August 19, 2009 It can be done but its a pain, why dont you just buy a TYZ rob the flywheel and sell it on. thats what i did. Dont be tempted to buy the motor for sale on ebay, as i already robbed that one years ago. Quote Link to comment Share on other sites More sharing options...
feetupfun Posted August 19, 2009 Report Share Posted August 19, 2009 I'm planning to spot weld a 14mm wide ring to end up with a total flywheel weight of 3.1kg Spot weld?????? If you electric weld (induce a strong, fluctuating magnetic field) near the magnets, they might not be magnets when you are done. If you flame weld near (heat up) the magnets they might not be magnets afterwards. I suggest two alternatives: Take the existing ring off, add your extra ring by welding and then refit it to the flywheel Take the existing ring off and fit a new ring the size you want to the flywheel Quote Link to comment Share on other sites More sharing options...
