280 Pro Base Gasket
diligaf
Head Spacer is the best value. Cheap and bike still runs good. Easier to KS and saves money on lower octane gas as well.
FWW is OK - but too pricey IMO
Base Gasket cheap, but as previous poster said, will change port timing. I havent tried it though - let us know if you do.
Tried thicker base gasket on a 300,ruined the top end and had a minimal effect low down,so I don't advise it.I would fit a flywheel wieght and/or a slow action throttle.It's more expensive but runs/rides much better,I think these engines are very sensitive to different port timing.Never tried a cylinder head spacer,but I know some who have had head sealing problems
i've put head spacers on 2 gassers and not had any sealing problems, i put a bit of silicone grease in the o ring slot to hold them in place when putting the head back on,maybe this was the problem the other guys have had?
