lian Posted August 20, 2009 Report Share Posted August 20, 2009 (edited) Lately i found weird noise from left side of bike wile running 4th and 5th gear. Noise is getting faster as i giving more throttle (frequency is about 3 times per 2 sec on 30 km/h. As faster speed, more frequently rattle), but when i shut throttle it disappears (i'm running on momentum), so it's not chain, wheels etc. At N and when clutching while 4/5th engine works fine too, w/o knocking. Rattle is metallic sound, like knocking 2 screwdrivers about each other. What it could be? Sherco 2.9 2004. Thanks! Edited August 20, 2009 by Lian Quote Link to comment Share on other sites More sharing options...
copemech Posted August 21, 2009 Report Share Posted August 21, 2009 Lately i found weird noise from left side of bike wile running 4th and 5th gear.Noise is getting faster as i giving more throttle (frequency is about 3 times per 2 sec on 30 km/h. As faster speed, more frequently rattle), but when i shut throttle it disappears (i'm running on momentum), so it's not chain, wheels etc. At N and when clutching while 4/5th engine works fine too, w/o knocking. Rattle is metallic sound, like knocking 2 screwdrivers about each other. What it could be? Sherco 2.9 2004. Thanks! More than likely the chain hitting a snag link under load and binding. Quote Link to comment Share on other sites More sharing options...
trialsnutterman Posted August 21, 2009 Report Share Posted August 21, 2009 As cope says put a new split link in or better still buy a new chain as it will probably be on it's last legs if it needs a new link. Quote Link to comment Share on other sites More sharing options...
lian Posted August 21, 2009 Author Report Share Posted August 21, 2009 (edited) Hmm, noise coming from engine as i can hear moving on speed, but not from lower side or backside of bike. I started bike standing on stand and turn 5th gear, giving gas, and heard no rattle. If it could be chain link, noise will be all the time in any gear.. Edited August 21, 2009 by Lian Quote Link to comment Share on other sites More sharing options...
copemech Posted August 22, 2009 Report Share Posted August 22, 2009 Hmm, noise coming from engine as i can hear moving on speed, but not from lower side or backside of bike. I started bike standing on stand and turn 5th gear, giving gas, and heard no rattle. If it could be chain link, noise will be all the time in any gear.. Well, what do you think it is then? The chain can do it, must be under load at speed, which increases load! Quote Link to comment Share on other sites More sharing options...
tony27 Posted August 22, 2009 Report Share Posted August 22, 2009 I'm beginning to wonder if its not chain at all & maybe something like pinking/pinging as you say it only happens under load in the higher gears & pulling the clutch in which unloads motor gets rid of it. Have you changed the type of fuel you're using lately? Quote Link to comment Share on other sites More sharing options...
copemech Posted August 22, 2009 Report Share Posted August 22, 2009 Would have said same, yet his frequency doen't neccessarily meet the mark. Quote Link to comment Share on other sites More sharing options...
tony27 Posted August 22, 2009 Report Share Posted August 22, 2009 What condition is your chain guide plate(plastic piece on top of swingarm) because sooner or later your chain starts to hit the mounting screws, not convinced thats the reason though Quote Link to comment Share on other sites More sharing options...
tony27 Posted August 23, 2009 Report Share Posted August 23, 2009 Another remote possibity is you got 1 loose sprocket bolt, hope not as that'll eat a groove into swingarm Quote Link to comment Share on other sites More sharing options...
trialsnutterman Posted August 26, 2009 Report Share Posted August 26, 2009 It will be the split link it only happens under load as that is when the link is stretched out causing it to misalign with the front sprocket and cause a click noise. Quote Link to comment Share on other sites More sharing options...
lian Posted August 30, 2009 Author Report Share Posted August 30, 2009 Thanks for everyone. It was missed chain lock and for that reason split link don't hold good both chain's sides. Now got to find lock. Quote Link to comment Share on other sites More sharing options...
