godzilla Posted August 21, 2009 Report Share Posted August 21, 2009 Has anyone got any tips for fitting rear sprockets, or should i just wack it on? I intend to use blue loctite. Quote Link to comment Share on other sites More sharing options...
tombo46 Posted August 21, 2009 Report Share Posted August 21, 2009 Has anyone got any tips for fitting rear sprockets, or should i just wack it on? I intend to use blue loctite. works for me! just make sure it go's on the right way round and you use a bit of loctite. check it every hour or so the first time you ride it to make sure it isnt coming loose, give it a quick waggle before you ride every time just to check, usually I just wait until it comes off before I put it back on though.... Tom Quote Link to comment Share on other sites More sharing options...
