Sprocket Fitting Advice
godzilla
  godzilla said:
Has anyone got any tips for fitting rear sprockets, or should i just wack it on? I intend to use blue loctite.
works for me! just make sure it go's on the right way round and you use a bit of loctite. check it every hour or so the first time you ride it to make sure it isnt coming loose, give it a quick waggle before you ride every time just to check, usually I just wait until it comes off before I put it back on though....
Tom
