scorpy Posted August 23, 2009 Report Share Posted August 23, 2009 Hello i have a 04 beta the rear shock has started to leak badly, lost most of the oil now. Is there someone out there that has had there shock repaired or had a exchanged one from Lamkins, i have gone onto Lampkins web site looks like the exchange ones are about Quote Link to comment Share on other sites More sharing options...
nzralphy Posted August 23, 2009 Report Share Posted August 23, 2009 Gosh that is a lot. I purchased a shock rebuild kit nz$45 and 2 shock bearings nz $80 and had it rebuilt by a shock expert nz$160 and it was good after that. You should be able to find a shock expert by asking at your local motorcycle shop. Ask for a specialist in off road shocks Quote Link to comment Share on other sites More sharing options...
anyoldiron Posted August 23, 2009 Report Share Posted August 23, 2009 Compared to the price of a new shock thats well over half price.If you can find someone who will recondition it for less,good for you. I don't think you are being tight but loads of things seem way expensive,as if money doesn't have much value right now.But anyway,get the best you can afford.Might be worth calling some of the big name shock experts like Falcon ,see what their price is,or go local like Ralphy says.I would always have faith in Lampkins.Expensive business throwing motorcycles at rocks,worth every penny if you ask me. Quote Link to comment Share on other sites More sharing options...
scorpy Posted August 23, 2009 Author Report Share Posted August 23, 2009 (edited) Hi thanks for your replys iam affraid this is getting worse, have taken shock off and noticed that the bottom of the shock mount is cracked right along lower face, i guess its going to be a new shock "****e happens". If i a need new rear shock is trp shocks ok as they seem to be cheaper than paioli. Cheers. Edited August 23, 2009 by scorpy Quote Link to comment Share on other sites More sharing options...
anyoldiron Posted August 23, 2009 Report Share Posted August 23, 2009 I would still try Lampkins on an exchange basis.It may not be an issue(the crack)to them and they might exchange it anyway. Quote Link to comment Share on other sites More sharing options...
theshercorider Posted August 23, 2009 Report Share Posted August 23, 2009 My shock died recently on my sherco, couldn't find anything second hand so went to buy new and found that a standard shock is more expensive then the likes of ohlins and trp. So I ended up spending Quote Link to comment Share on other sites More sharing options...
yamahaty250xox Posted August 23, 2009 Report Share Posted August 23, 2009 John lampkin Also rebuilds these shocks! Send it too him and it will be Quote Link to comment Share on other sites More sharing options...
scorpy Posted August 26, 2009 Author Report Share Posted August 26, 2009 Hi just to let you know have got a recon shock as old had crack in bottom fixing as well as leaking. A service would be about Quote Link to comment Share on other sites More sharing options...
