xtriple Posted August 23, 2009 Report Share Posted August 23, 2009 In the manual it says to put silicone grease between the main bearings and the crank seals, is this needed? Can it be a different kind of grease? Thanks for the help. Quote Link to comment Share on other sites More sharing options...
motovintage Posted August 25, 2009 Report Share Posted August 25, 2009 not really sure where they are telling you what to grease, you need some kind of lube on the seal, I usually just use 2-cycle oil of good quality, I also oil the bearing liberally with the same Quote Link to comment Share on other sites More sharing options...
