mgb_phil Posted August 27, 2009 Report Share Posted August 27, 2009 Hi All, I'm new to the forum so go gently on me! I'm building a C15 for chugging up and down green lanes and the occasional really easy trial. I've decided to fit lights and have converted to 12V using a solid state regulator/rectifier. My question is, can anyone suggest a battery I can use? I just wanted the smallest, lightest 12 Volter I can tuck away somewhere with enough capacity to spit a few sparks out when I start the bike. it would be highly advantageous if I could fit it in any orientation so sealed or AGM would be ideal. I'm not particularly concerned about being able to keep the lights at full brightness at tickover. I don't really understand electrisity as you can't turn or mill it... thanks in advance... Phil Quote Link to comment Share on other sites More sharing options...
tonyp Posted December 7, 2009 Report Share Posted December 7, 2009 Did you find a solution to your problem. I'm in thesame situation ? Quote Link to comment Share on other sites More sharing options...
b40rt Posted December 7, 2009 Report Share Posted December 7, 2009 have a look here http://www.screwfix.com/cats/A331779/Elect...ealed-Lead-Acid Quote Link to comment Share on other sites More sharing options...
davetom Posted December 7, 2009 Report Share Posted December 7, 2009 Try a KTM off-road dealer, i had an `02 400 KTM EXC enduro with electric start and the battery is very compact and also quite powerful.I used to use it on my BSA A65 also Quote Link to comment Share on other sites More sharing options...
mgb_phil Posted December 17, 2009 Author Report Share Posted December 17, 2009 Hi Guys, That screwfix one looks to be the kind of thing I'm after. I'll pick one up and report back on its performance. As long as the output from the alternator isn't too high, resulting in overcharging of the battery. At the price it's worth experimenting with though. Regards... Phil Quote Link to comment Share on other sites More sharing options...
