August 30, 200917 yr Here are a few shots of the recently aquired Bultaco's. Matador Mk 3 M70 Sherpa T M159 These are literally basket cases both bike have engines pulled and in multiple boxes. I just started to sort out the boxes and try to figure what goes with what. It also came with an old engine serial number M 400... D
August 30, 200917 yr Author You are right about the serial # m 7502185 I was going on my memory and I was wrong.
August 31, 200917 yr Author The model 10 engine is locked up , has a few broken cooling fins on the head, ans is missing the side cover. What is the value of it roughly? Thanks for the help with I.D. Sunny
August 31, 200917 yr The model 10 engine is locked up , has a few broken cooling fins on the head, ans is missing the side cover. What is the value of it roughly?Thanks for the help with I.D. Sunny Roughly equal to a paperweight.
October 11, 200916 yr The spare motor is actually a mk2 matador ,visually the same as the M10 apart from the inlet manifold and internally the same apart from gear ratios ,serial M4 , a lot have been coverted in the states as M10 clones
October 11, 200916 yr Author I sold the matador and engine to a member of this board. I will let him post about the purchuse if he wants to. I am curious if he has made any progress on the project? Mike
October 12, 200916 yr Hi Mike After getting the stuff home the next day and unloading it I found that the matador is actually very complete. I have the all the parts required to finish it accept the head pipe and triangular rear pipe. These are both easy to come by. Interestingly the wiring harness on the matador is completely original and intact. Nobody ever hacked it up or changed it. This is a huge bonus for me because I can copy it for my other matador. I have the wiring diagram but it can be hard to follow, now that I have the original it makes it much easier. The engine is in good shape. I'll put a new piston, bearings, gaskets and it will be fine. I checked and the original electronic ignition is also still working which is another huge bonus. All in all I am very happy with the purchase. I think I will use it to commute to work next year. Also I put the bike in my name so the paperwork was a bonus also. So there you have it. Was great to meet you and I hope you finish that M159 soon. Give me a shout anytime if you need anything. I mentioned getting you the service manual but it slipped my mind a few weeks ago so I will send you a copy. Talk soon Steve
October 12, 200916 yr Author Great News. It was too much of a project for me. Glad it made its way in to the hands of the right person. The guy I bought it from was going to junk it. I ordered a set of rings and the clutch thrust bearing so that will complete the engine on the 159. I also made up a brake rod out of 1/4 inch aluminum round stock and made a barrel bolt out of steel round stock. Tapped and threaded the works and it works well. Really just need fenders, a seat, and a set of trials bars. Mike
