orange250 Posted August 30, 2009 Report Share Posted August 30, 2009 (edited) I fell off today and the throttle housing turned, I went to tighten it and looks like the nut has pulled through the plastic so it wont. I guess I cant get away with just a throttle top, so how do I know if it was a fast or slow throttle? Also am I better going for a slow if I dont find out? I also caught my knee on the fuel cap and broke of the breather. I tried to get out what was in there so I could maybe put a new one in - but its broke clean and I even tried putting a self taper in to pull it out with no luck. Does this mean a whole new cap then? I was only trying to practise Edited August 30, 2009 by Orange250 Quote Link to comment Share on other sites More sharing options...
richt Posted August 30, 2009 Report Share Posted August 30, 2009 Is it a Domino throttle? Peel back the hand grip and check what colour the throttle tube is! If it is white you have a 'fast' one If it is black you have a 'slow' one All the components are interchangable so you could get the oposite to what you have now and then you try both see which you prefer. Quote Link to comment Share on other sites More sharing options...
orange250 Posted August 30, 2009 Author Report Share Posted August 30, 2009 (edited) Is it a Domino throttle?Peel back the hand grip and check what colour the throttle tube is! If it is white you have a 'fast' one If it is black you have a 'slow' one All the components are interchangable so you could get the oposite to what you have now and then you try both see which you prefer. Thanks, its a Domino and its white. Edited August 30, 2009 by Orange250 Quote Link to comment Share on other sites More sharing options...
orange250 Posted August 30, 2009 Author Report Share Posted August 30, 2009 Just orderd a slow action one. Is it obvious which parts change between for slow/fast? Quote Link to comment Share on other sites More sharing options...
totalshell Posted August 30, 2009 Report Share Posted August 30, 2009 yeh the throttle tube is the only difference in fact the difference is the shape of the cam at the end that pulls the throttle cable through easy swap // getting the grip off will probably the hardest part.. Quote Link to comment Share on other sites More sharing options...
orange250 Posted August 31, 2009 Author Report Share Posted August 31, 2009 Thanks. Anyone any thoughts on the petrol cap? Quote Link to comment Share on other sites More sharing options...
kluson Posted August 31, 2009 Report Share Posted August 31, 2009 sorry to hear you fell of, hope you're oK Quote Link to comment Share on other sites More sharing options...
richt Posted August 31, 2009 Report Share Posted August 31, 2009 The cap on mine is plastic, if I had broken it the way you describe then I think would just replace the cap. Quote Link to comment Share on other sites More sharing options...
crasher Posted August 31, 2009 Report Share Posted August 31, 2009 i broke the breather nipple on my 05 gasser in the same way yours has gone , i drilled the hole out a bit and threaded a grease nipple in, put the breather pipe on there, seems to work okay Quote Link to comment Share on other sites More sharing options...
orange250 Posted August 31, 2009 Author Report Share Posted August 31, 2009 sorry to hear you fell of, hope you're oK Yes fine thanks, just clumsy! Quote Link to comment Share on other sites More sharing options...
orange250 Posted August 31, 2009 Author Report Share Posted August 31, 2009 The cap on mine is plastic, if I had broken it the way you describe then I think would just replace the cap. Thanks, but mines a metal one- not sure of their cost. Quote Link to comment Share on other sites More sharing options...
orange250 Posted August 31, 2009 Author Report Share Posted August 31, 2009 i broke the breather nipple on my 05 gasser in the same way yours has gone , i drilled the hole out a bit and threaded a grease nipple in, put the breather pipe on there, seems to work okay Thanks, may give this a shot. Quote Link to comment Share on other sites More sharing options...
jse Posted August 31, 2009 Report Share Posted August 31, 2009 i broke the breather nipple on my 05 gasser in the same way yours has gone , i drilled the hole out a bit and threaded a grease nipple in, put the breather pipe on there, seems to work okay A 90 degree nipple should work fine, provided you removed the spring/ball one-way valve where the gun tip would ordinarily attach. Otherwise, you are running a "non breathing" breather and this could cause problems up the road, especially with the seals. Jon Quote Link to comment Share on other sites More sharing options...
crasher Posted August 31, 2009 Report Share Posted August 31, 2009 ah yes, well spotted jon, forgot that i'd poked the ball out of the straight nipple i used i may have run a small drill bit down it as well, can't remember though, must be my age! Quote Link to comment Share on other sites More sharing options...
bigfoot Posted September 1, 2009 Report Share Posted September 1, 2009 Just replace the cap. I broke one a couple of years ago and it wasn't expensive to replace. In fact the price was a surprise. Quote Link to comment Share on other sites More sharing options...
