Scorpa Easy Parts? Manual Clutch Bleed?
rij
Hi does any one know if there is ment to be a bango bolt with a bleed nipple on it on a scorpa easy? cant see antother way of bleeding it??
and where do you get parts from?? help its driving me mad!! Rich
Hi there it is a messy job, but you have to bleed it through the banjo. Strange i know but that's how its done, bleed it as though you were bleeding a brake but instead o cracking the bleed nipple you have to crack the banjo.
Just make sure you have a rag near by to soak up all the fluid.
try BVM moto for spares 01453 762743 they should be able to supply all your parts
hope this helps:)
Dean
  • 1 year later...
