Betor Gas Shocks
nh014
Two questions on Betor gas shocks (on a Cota 348).
1. Should the shocks be positioned with the oil reservoir and air valve end up, and springs down, or vice versa. I've seen them both ways at local meets. Installed with the springs down creates minor brake cable interference on the Cota 348, but that appears to be the most frequently seen installation.
2. What is the recommended air pressure on these shocks.
