neo Posted September 12, 2009 Report Share Posted September 12, 2009 Hi. Does any know the size and thread of those 4 small cross point screws that hold the reeds to reed block?. I messed mine up trying to unscrew them today and need to buy some more on Monday. Also, once you fit Boysean reeds what changes to the pilot jet are needed? Best of balance. Neo Quote Link to comment Share on other sites More sharing options...
lowbrow Posted September 12, 2009 Report Share Posted September 12, 2009 On a GasGas they're M4x8 and I'd guess the Sherco is the same, but not certain. I've fitted Boysen reeds to several Gassers over the years and never had to re-jet. Some needed a twiddle of the mixture screw, but nothing major. Good luck getting those screws. Dave Quote Link to comment Share on other sites More sharing options...
baldilocks Posted September 12, 2009 Report Share Posted September 12, 2009 I went up one pilot jet size on my 290 Sherco when I fitted boyesens Quote Link to comment Share on other sites More sharing options...
tony27 Posted September 12, 2009 Report Share Posted September 12, 2009 Neo you're going to have problems getting the right screws from anyone but sherco unless you change to buttonhead capscrews. I run a v-force3 reed block which doesn't have screws so have no idea on their sizing. Take the reed block to a fastening supplier & hopefully they can help you Quote Link to comment Share on other sites More sharing options...
neo Posted September 12, 2009 Author Report Share Posted September 12, 2009 Just to clarify....it is the tiny cross-point screws that hold down the actual reeds (not the reed block) that I need to fine the size of? The 06 parts book does not have a number for these....so assume they're included with the block. Many thanks. Neo Quote Link to comment Share on other sites More sharing options...
tony27 Posted September 12, 2009 Report Share Posted September 12, 2009 You're lucky I had my verniers at home & know where the original reed block is, the screws are M3 x 5 or 6. It would still pay to take it with you when you see the fastening supplier as 1 trip to get the right size is better than 2 Quote Link to comment Share on other sites More sharing options...
neo Posted September 17, 2009 Author Report Share Posted September 17, 2009 Thanks Tony, Sorry for the late reply. Best of balance to you Neo Quote Link to comment Share on other sites More sharing options...
neo Posted September 19, 2009 Author Report Share Posted September 19, 2009 Neo you're going to have problems getting the right screws from anyone but sherco unless you change to buttonhead capscrews. Now I know what you mean tony...I had to file the outer edge of the screw heads a bit to make the reed block go back in. But on the plus side, there no way these screws could ever undo themselves and come out Best of balance. Neo Quote Link to comment Share on other sites More sharing options...
tony27 Posted September 20, 2009 Report Share Posted September 20, 2009 Thats a major bonus, run a v-force reedblock & never worry about screws again like me Quote Link to comment Share on other sites More sharing options...
