thespikeyone Posted September 20, 2009 Report Share Posted September 20, 2009 Hi folks Can anyone tell me how to set up the rear suspension properly? At the moment I have the spring wound as tight as it'll go and the damping set so I can (try) and hop and bop, but when I ride along a trail between sections the rear bottoms out and the exhaust rubs on the rear tyre. any help would be great. Spike Quote Link to comment Share on other sites More sharing options...
paulthistle Posted September 20, 2009 Report Share Posted September 20, 2009 The 250f bottom out bumper(rubber) is prone to disintergrating. The fragments get in the shock valve stack and makes the suspension very loose. with little comression and rebound damping. It can be repaired but the shock body has to be replaced to do it. Quote Link to comment Share on other sites More sharing options...
nzralphy Posted September 21, 2009 Report Share Posted September 21, 2009 (edited) You need to set the spring up so the bike sags 1/3 of it's travel when you stand on it. NO MORE and NO LESS. Get someone to help check this. Note if you are heavy (90kg +) you will need a heavier spring otherwise you could blow through your travel If the bike blows through its travel you should have the shock oil serviced. It sounds like your shock is ready for a rebuild. Most rear shocks have a rebound damping adjuster - set this so it slows down the rear springing action. The bike should not bounce too easily. Hopping the back is all about technique.... NOT by setting the rebound damping too soft. If you do this the bike will get LESS traction all the time. Then again, you maybe happy with this i suppose. Edited September 21, 2009 by NZRalphy Quote Link to comment Share on other sites More sharing options...
