Fantic 249 High Port Low Port
lee harris
Hi Gents,
I just picked up a good 300 barrel with no fin damage. It has no cut out for the bigger flywheel so came off a 300
The bore is 72mm meaning it came from france. The 300 was sold there with 240 instead of 249 cc for insurance reasons.
It needs a new piston so I will get it bored to 74mm and 249.
My question is on porting. The 300s all had a so called low port motor, later 249s where high port motors. I think it refers to the exhaust port, I can compared to a 303 barrel I have but do I want to change the exhaust or other port timing?
Info please!!!
Lee
Lee , on the 240 barrel I've got that has the major porting changes to the known stock one I've got , most of the port work was done on the exhaust and transfers ... And just a bit on the intake side . But with Chris's OKO and the iridium plug , K&N airfilter and The new stator and coil , it will idle slow enough that you can almost count the rpm and still go wide open without any hesitation . All without a sharp edge anywhere in the powerband ... When I have it apart to get it replated for the forged piston I've got waiting to go in , I'll send you some scaled comparison photos .
But it may be awhile as I've not noticed a drop in compression yet ... Ask Classic what he does to the early 300's to stop the spark knock ...
Glenn
