benbeta23 Posted September 23, 2009 Report Share Posted September 23, 2009 Hi, i have a Gas Gas 300 pro 2009, & since day one when i bought it off Sam Haslam it has done nothing but pink most of the time, i had the carb set up exactly how it is reccomended (according to GG UK), 125 main jet, 45 pilot, 3 slide, JJH needle with clip in the middle, doesn't seem to like that though, it was a bit chokey on bottom end & at one point it sounded like it was nearly completly out of fuel but had half a tank left in, had a look at the plug & it was really black & oily which i presume is a very rich mixture which has created this. I dropped the clip on the needle one down & seems a bit better now but pinking, not when you rev the bike, only when you say are going up a hill or get to the top of a hill & blip the throttle, occurs more in a lower gear. The bike either eats spark plugs or is pinking all the time, can never seem to win with it!! Any Help would be Really Appreciated, Cheers, Ben. Quote Link to comment Share on other sites More sharing options...
shercoman2k8 Posted September 23, 2009 Report Share Posted September 23, 2009 You have adjusted the mixture screw, right? Quote Link to comment Share on other sites More sharing options...
benbeta23 Posted September 23, 2009 Author Report Share Posted September 23, 2009 Yep it's just about been turned everywhere possible, it's currently on 1 turn out as it should be, but still pinking. Quote Link to comment Share on other sites More sharing options...
lowbrow Posted September 23, 2009 Report Share Posted September 23, 2009 Are you using super unleaded? If not this definitely helps. Quote Link to comment Share on other sites More sharing options...
benbeta23 Posted September 23, 2009 Author Report Share Posted September 23, 2009 Are you using super unleaded? If not this definitely helps. I tried it at one point, but still pinking as i can remember, will give it another go though see if it helps. Cheers Quote Link to comment Share on other sites More sharing options...
lowbrow Posted September 23, 2009 Report Share Posted September 23, 2009 I'm running the same set up as you Ben and don't have problems. I always use 98 octane fuel, mix at 66:1 and store it in a steel, not plastic, container. Have had pinking problems in the past, even with super unleaded fuel, particularly when snapping the throttle shut at the top of a climb, or running on light throttle between sections, and that was due to an air leak on the intake side. Suggest you have a look around the reed block to crankcase and manifold joints and make sure there are no leaks. Hope you get it sorted soon. Dave Quote Link to comment Share on other sites More sharing options...
benbeta23 Posted September 23, 2009 Author Report Share Posted September 23, 2009 I'm running the same set up as you Ben and don't have problems. I always use 98 octane fuel, mix at 66:1 and store it in a steel, not plastic, container. Have had pinking problems in the past, even with super unleaded fuel, particularly when snapping the throttle shut at the top of a climb, or running on light throttle between sections, and that was due to an air leak on the intake side. Suggest you have a look around the reed block to crankcase and manifold joints and make sure there are no leaks. Hope you get it sorted soon. Dave Thank you very much mate, very appreciated. will have a very good look through it. Quote Link to comment Share on other sites More sharing options...
b40rt Posted September 23, 2009 Report Share Posted September 23, 2009 you could try octane boster. Quote Link to comment Share on other sites More sharing options...
jam Posted September 23, 2009 Report Share Posted September 23, 2009 Try 3 to 3 and a 1/4 turns out, standard on GasGas carbs as its a fuel screw not an air screw.............has always worked for me! Quote Link to comment Share on other sites More sharing options...
the addict Posted September 23, 2009 Report Share Posted September 23, 2009 AvGas Quote Link to comment Share on other sites More sharing options...
jordtxt Posted September 23, 2009 Report Share Posted September 23, 2009 just a bit of learning, what is pinking? also i use standard 95 petrol and i noticed you mentioned using 98, does it make much difference? Quote Link to comment Share on other sites More sharing options...
benbeta23 Posted September 23, 2009 Author Report Share Posted September 23, 2009 (edited) just a bit of learning, what is pinking? also i use standard 95 petrol and i noticed you mentioned using 98, does it make much difference? Full definition of pinking there for you mate. my bike seems to like it anyway. http://en.wikipedia.org/wiki/Engine_knocking Edited September 23, 2009 by GasGasben Quote Link to comment Share on other sites More sharing options...
bikespace Posted September 24, 2009 Report Share Posted September 24, 2009 just a bit of learning, what is pinking? also i use standard 95 petrol and i noticed you mentioned using 98, does it make much difference? I will NEVER put low octane fuel in mine. Absolutely definitely makes a difference. I've done it in the past when I've had to, filling up in the sticks and no super unleaded, then forgotten all about it, and been reminded when the bike starts pinking. It's maybe 40 or 50 pence difference a week - same with plugs - Quote Link to comment Share on other sites More sharing options...
manx2day Posted September 24, 2009 Report Share Posted September 24, 2009 Never really had much of an issue with it on my bike, only occasionally after a long run on the road it starts to knock slightly. I let the revs die off and it seems to go back to normal! Never changed the settings on my carb from when i bought it, it's an 07 which i got at the end of 06. I run Shell V-Power with a 50:1 mix. Very rarely run anything else, if i can help it. Quote Link to comment Share on other sites More sharing options...
peterb Posted September 24, 2009 Report Share Posted September 24, 2009 Hi Ben, On my last 3 PRO 300's fitted with a Keihin carb, they always run lean with the std factory setting and pink as you found out. I use Shell V power at 50:1, nothing fancy just high octane in this part of the world. You need a larger main jet, 127 or 128. Clip on 2nd notch from bottom, std slide I thought was 35 - can't remember. JJH needle is ok for the younger splatt attack lads, GJH needle gives vastly better low end control for more, er mature riders! 45 I find too rich for pilot, use a 40. Use an Iridium plug, won't foul up. The Keihin has no internal fuel filter, best to have an inline one fitted. Give the carb a thorough clean out just in case. Pilot (air) screw on the Keihin should be around 3/4 to one turn out, DellOrto pilot is 3.5 to 4 turns out. Ta ta, PeterB. Quote Link to comment Share on other sites More sharing options...
