Cota 200 Gearbox.
ikb
Hi,
I am puting my Cota 200 back together and I need to know how much end float the gear shafts should have?
And which end the shims should go?
I am disregarding any shims I took out as it had been rebuilt by Neanderthal Man!!
If anyone has an exploded diagram of the gearbox that would be good as I have made some educated guesses on how it goes!!!!
Thanks Ian
Basically, you want the shafts centered in the cases with at least one shim at each end.
End play? As little as possible without clamping down on the shafts. 2 or 3 thou.
Oops got the end float right but shims on the left side only!! I have shimmed the selector drum to suit and all gears select ok!
  • 3 weeks later...
