Spark Plugs
thomastomsk
hi might seem like a daft question but what does it mean when the end of the spark plug is black and oily....i now surten states of the plug can mean different things just can not remember what.any info would be greatfull thanks.
It could mean that the jetting is too rich, the air cleaner is dirty, too much premix oil was accidently added to the fuel, the exhaust pipe has too much carbon in it, the mufflers somehow got clogged, the ignition system has low output, the carb float level is off or the float valve is not sealing well, things like that.
Jon
Gday, its unlikely thats the problem. Start with your air cleaner and go from there as Jon said above. Check carb related things first (after the air cleaner) and of course make sure you have the correct plug for your bike. Fresh fuel too.
Cheers,
Stork
