Sherco 06engine Hunting
matthew
hi there can got a problem where the enginge is hunting on the bottom end ive done the usuall .
stripped the carb and blown out whith air compressor
changed the fuel.cleaned the fillter
checked float hights
changed the spark plug
its got to be a fuel problem as i gets better as iput a bit of choke on can anyone shed any light on this
cheers
How well have you cleaned the carb, I take it you've at least taken the jets and mixture out then blown through with compressed air, if not that would be my 1st suggestion
Also have you cleaned the air filter and box, what's the filter like?
After that check for a air leak on, manifolds, gaskets, crank seals, to do this you need to pressurise the cases to about 8psi and then check it after 10mins hopefully it should be still holding 8psi, I've got a bung that I fit in the exhaust port and another to go in the inlet manifold with a air valve that you can borrow, if you like, send me a PM.
  • 2 weeks later...
