stushine Posted September 27, 2009 Report Share Posted September 27, 2009 just bought my self a 2007 sherco 290 to replace my 2002 sherco 290.. just wondering a few things.. whats the fuel / 2 stroke mixture? how do i tell that it really is a 290 and not a 250? on the frame i see it has a picture of a fuel tank and says 98 on it, i presume this means 98 ron fuel? (super unleaded?) cheers Quote Link to comment Share on other sites More sharing options...
copemech Posted September 27, 2009 Report Share Posted September 27, 2009 Hi, No different on the mix, many use 80:1 ratio. Look at the motor number, below and aft of the carb, should start awth SH290 -----. Super unleaded, yes at 98 ron Quote Link to comment Share on other sites More sharing options...
stushine Posted September 28, 2009 Author Report Share Posted September 28, 2009 ok cheers my 2002 sherco i was running normal 95 ron fuel and for the mix i was doing... 5 liters petrol 100ml oil... i think thats 50:1? Quote Link to comment Share on other sites More sharing options...
trialsnutterman Posted September 29, 2009 Report Share Posted September 29, 2009 They run fine on 95 but sometimes, if going down the road for example they can start to knock using 98 helps. You oil amount is correct, if your using a good quality fully synthectic 2 stroke oil you can run a lower ratio, I run mine at 75:1 I think it helps prevent the exhaust getting bunged up with oil. Quote Link to comment Share on other sites More sharing options...
