Tubeless Rim On Fantic 200 Hub
somerset steve
I have a 74 TY Yamaha with a tubeless rim on the rear, used a Fantic rim, laced with stock length spokes, works great don't have to worry about pinching tubes. Fantic and Gas Gas TXT's had 36 spoke holes maybe some of the Sherco's, have bought rims off of ebay, going to lace in either a Gas Gas or Fantic rim onto another modified hub and its going onto my Tiger Cub.
Fred
I presume you are looking to do this as tubeless are better than tubed - is the difference significant
Not to do with performance for me, rather the limited choice of tubed tyres now available, IRC and Michelin.
The IRC grips as well as anything but has been spoilt by the butter-like strength of the sidewalls, if you weigh over about 12 stone they roll around all over the place. Increase the pressure to over 5psi to stiffen it up and you lose grip. If you can put up with the rolling they're fine but at 17+ stone I can't and I'm sick of the bloody things. They puncture easily too.
The Michelin isn't a tubed version of the X11, I've no idea what it is but it's about as good as a racing slick on ice when used in a muddy trial. Didn't have one on long enough to try it on rocks. I'd bet a Pirelli MT43 is better....
Soft sidewalls apart. as regards performance in terms of grip between the IRC tubed and any tubeless tyres, if there is a difference, you'd have to be able to ride well enough to push the tubed tyre to its absolute limit and then be able to ride the same terrain with a tubeless and feel any difference. 95% of trials riders don't have to worry about that.
Main advantage of tubeless is wider choice, less chance of punctures, stiffer sidewalls.
Some tubed rims will seat a tubeless tyre with a tube fitted with no problem. Again there is a theory that the tubeless doesn't work as well with a tube in but if a rider can tell that they should be in WTC I reckon.
